6 hours ago, FelixSpacito said:
Thank you, could you link it so i can view the width and compare it to others??
14 minutes ago, Naxa4500 said:
I use this: https://www.amazon.com/ASUS-PCE-AC55BT-B1-Wireless-Bluetooth/dp/B0713RRZMB
I have a GTX 980 Ti above it and it completely engulfs the PCI-E slot above it with barely any clearance like your situation will be, but it works great, no issues.
An extension to what I just said, here's what it looks like in my PC:
https://linustechtips.com/topic/1254823-pci-e-wifi-card/#findComment-14092528
