It would be temporary could I get away with it?
For a week or so. Don't do it if you don't have to. Just ghetto mount it to the bottom of your case or something. Just don't stack them.
The biggest risk is knocking your PC tower over. and damaging either the motor in the HDD or damaging the platters themselves.
If I were you, I would hold out on stacking the drives, if you don't need to.
https://linustechtips.com/topic/125452-hdd-installing-help/#findComment-1667704
If I were you, I would hold out on stacking the drives, if you don't have to.
Would it be better for me to place it on top of a non' working optical drive?
https://linustechtips.com/topic/125452-hdd-installing-help/#findComment-1667724
Yes. As long as that optical drive isn't working. Heat can also be an issue, but it won't kill your drives.
It comes down to personal preference. Yes, it will work just fine, and you probably won't have any issues. But, I wouldn't do it because I like to be careful.
https://linustechtips.com/topic/125452-hdd-installing-help/#findComment-1667734
You don't want either of the two sides to be fully covered by anything.
I bet you could get away with creative use of rubber bands, but this is not recommended.
Woo!
https://linustechtips.com/topic/125452-hdd-installing-help/#findComment-1667742
