5 hours ago, Bharath1910 said:
No it is not working....and it is resetting the resolution to default when I save it.....
I append it to the existing one
Resetting to default in "/etc/default/grub" or in Grub itself?
Did you remove the "#" in front of "GRUB_GFXMODE" to uncomment it?
Did you update grub, "sudo grub-mkconfig -o /boot/grub/grub.cfg"?
Did you get the Resolution from Grub using "videoinfo"?
On 10/4/2020 at 5:52 PM, Bharath1910 said:
when I installed a theme for grub menu it is low resolution
I'm assuming, based on this line, that before you installed the theme GRUB was fine.
We're going to need to know what exactly you did to install the theme because that's probably where the issue is.
Just as a starting point, what happens when you disable the theme and go back to default GRUB?
