Gigabyte GA-A320M-H, Socket AM4
AMD Ryzen 5 2600, 3.9GHz, 19MB Socket AM4, Wraith Stealth cooler
Corsair Vengeance LPX 16GB (2x8GB) DIMM, DDR4, 3000MHz, CL15, 1.35V, XMP 2.0, Black
Solid State Drive (SSD) Kingston A400, 480GB, 2.5", SATA III
Corsair CV Series™ CV650, 80 Plus® Bronze, 650 W
KFA2 GeForce® RTX™ 2060 SUPER™ 1-Click OC LED 8GB GDDR6, 256-bit
https://linustechtips.com/topic/1254102-will-this-build-work/
Yes it will work, but you should:
- Upgrade the motherboard to B450 or B520
- Lower the PSU to 450w ( so you can upgrade to B450).
https://linustechtips.com/topic/1254102-will-this-build-work/#findComment-14084928
-> Moved to New Builds and Planning
2 hours ago, IBNU426 said:
why would i
Probably as its better value. You really don't need over 500W PSU, more so since you can't OC CPU on that chipset.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1254102-will-this-build-work/#findComment-14085166
