Hi, I'm new to this forum. I have a problem with my GPU (Vega 64 Air). When playing I have a 'black screen' problem, the speed fun of my card is 100%. I replaced my old PSU with a 1000w Cooler Master (Oversized I know), thinking this was the problem. But nothing, the problem exists and I don't know how to solve it anymore. I thank all those who will give me a hand in this now become 'problem'.
https://linustechtips.com/topic/1253660-gpu-problem-needs-help/
Is it when playing a specific game? Also what are your other specs?
Mini-ITX Desktop: i9-9900K@5GHz, 32GB TridentZ RGB 3200MHz, Asus Strix Z390-i, EVGA 3090 Hybrid FTW3, Samsung 970 EVO+ NVMe 1TB, Lian Li O11 Air Mini White
Plex/Minecraft Server: Dell PowerEdge T320, Xeon E5-2470 v2, 48GB RAM, 19.25TB storage, RTX A2000 6GB
Tablet: iPad Pro 11” M1
https://linustechtips.com/topic/1253660-gpu-problem-needs-help/#findComment-14081638
9 minutes ago, Slenderman0039 said:
I have the same problem for every game. (occurs when I increase the video settings)
CPU : Ryzen 5 2600
MB : Aorus B450 Elite
GPU : Vega 64 Air
PSU : Cooler Master 1000w
RAM : 16 GB DDR4 3200Mhz HyperX
Air dissipator
And 3 RGB fans
Which settings are you increasing? And are you watching the temperatures of the card?
https://linustechtips.com/topic/1253660-gpu-problem-needs-help/#findComment-14081685
I Want to specify that i have already used another GPU (RTX 2080) in my build and it works, i have so unistalled and reinstalled drivers (
but the problem already existed) . When my vega 64 starts to crush i see a drop of FPS in game and after this , i have a black screen.
When i set the high/epic settings for example on Fortnite, but not only this, i have also seen black screen when i play in 'borderless' and try to click on windows button of my keyboard (when resolution change). What software should i use?
https://linustechtips.com/topic/1253660-gpu-problem-needs-help/#findComment-14081697
It sounds like an AMD software issue then, which I'm not very experienced in dealing with
https://linustechtips.com/topic/1253660-gpu-problem-needs-help/#findComment-14081715
