Noob advice required
Solved by AndrewZScorpion,
5 minutes ago, welshmanofwar said:Would my motherboard be compatible with a dual slot GPU?
Yes, dual slot just means that it overhangs the next PCIe slot. (So if you have any other PCIe devices you might need to move them to another slot)
6 minutes ago, welshmanofwar said:Would it actual fit in my current case?
Looks to me like it should.
