How about it y’all?BB286E2B-BE0E-4A49-85DB-45C83F96CDD7.jpeg.d84fcf549472046ef91c95c297405f3a.jpeg
The front can probably be cut out and replaced with acrilic so you can see in.
the sides of the inside can be cut out to fit probably 120 mm fans, 3 on the side 2 on the top. 1BACE25F-1BCB-4DFD-AB73-26EB1246437B.jpeg.0511916151e8de1c6369cc7dca69f2f2.jpeg
it could totally fit an atx motherboard resting on the back
And then a final cutout in the middle of the back near the bottom for the psu fan in or something.
and maybe a cutout foot front panel i/o on the top.
Edited by Link109
https://linustechtips.com/topic/1252732-ultimate-portable-pc-case/
@Link109 please add some context to your topic.
FYI, this forum has no upvote options.
 CHRISTIAN MEMBER
Not sure if you are aware, but this is just a suitcase....
Check out my Lian Li TU100 if you want to see a real travel case.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Ik, it’s just something no one would expect 👀, also that thing looks like it weighs a ton, dontcha wish it had wheels??
It's 4,7kg and I already traveled with it. It's really no fun but you can put it in a backpack and actually carry powerful hardware with you.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
