Hi.
So I built a new computer in August. Everything was working perfectly for a while. Then after about 1-3 months of use I started getting a problem with booting. I just turned the system on and off (sometimes a few times) before it would boot properly.
After a while rebooting didn't work at all. I think it was November when I started to have real problems with it.
I am not sure whether it's my graphics card or my motherboard, but it is one or the other.
Thankfully I have 2 7950's as I was running Crossfire. Mobo is an Asus P8Z77-v if that helps.
My rig is watercooled, but I haven't had any leaks (that I know of... I'm pretty diligent as I'm scared of tubing jumping out and drenching my system).
Can supply more info if needed, any help would be great!
Thanks!
https://linustechtips.com/topic/12526-post-problem/
