Hey all, long time reader, first time poster. I recently purchased a Gigabyte Windforce OC 11g 2080ti, and sadly it's cooling is a little lackluster (I have searched and searched, and came up with the same universal truth.. it's cooler sucks..)
So I'm looking to change it's cooler, water cooling isn't an option as I am in a NZXT H1. Ideally, I'd like to get ahold of a heatsink from a Gigabyte Gaming OC 2080ti and its heatsink is similar to mine, just a fair bit thicker.
Being it uses a reference PCB, I'm not opposed to using a heatsink from another brand either as long as it works better than the Windforce cooler.
So my question is this, does anyone who may have upgraded to water cooling have a 2080ti heatsink they'd like to sell? Or can point me in the right direction to find one? Sadly eBays options are REALLY slim (a MSI Ventus which the shipping cost is the same as the cost of the cooler, a couple Strix OC 2080ti coolers but those use another PCB, a few blower heatsink (HELL NO!!) And a founders edition missing it's screws and backplate, so that doesn't do me any good.)
Many thanks in advance for anyone that can help.. also the Artic cooler is too big (already looked at it.)
https://linustechtips.com/topic/1252435-gpu-thermal-issues/
you can make a post in our classifieds section looking for a reference cooler. does a raijintek morpheus ii fit in the h1?
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1252435-gpu-thermal-issues/#findComment-14070402
Sadly, I can't post in classifieds because I'm a new member (100 post minimum it seems) I looked at the Rajintek and Arctic coolers and they are both way too big for my case, not to mention neither have any contact to the VRAM or VRM, and from what I understand, on a 2080ti that is no bueno...
Best I can do at the moment is just keep refreshing that eBay list every day or 2 till I find one.. I wish the ROG Strix one would fit.. but it's PCB is much bigger.
https://linustechtips.com/topic/1252435-gpu-thermal-issues/#findComment-14077229
