Djikstra's algorithm implementation within python with classes
So here's my code:
class Vertex:
    def __init__(self, name):
        self.name = name
        self.connections = {}
    def addNeighbour(self, neighbour, cost):
        self.connections[neighbour] = cost
class Graph:
    def __init__(self):
        self.vertexs = {}
    def addVertex(self, newVertex):
        new = Vertex(newVertex)
        self.vertexs[newVertex] = new
    def addEdge(self, src, dest, cost):
        self.vertexs[src].addNeighbour(self.vertexs[dest], cost)
    def dfs(self, start, end, visited):
        visited[start] = True
        print(start, end=' ')
        if start == end:
            # End node found
            return True
        else:
            # Use depth first search
            for connection in graph.vertexs[start].connections:
                if visited[connection.name] == False:
                    if self.dfs(connection.name, end, visited) == True:
                        # Return true to stop extra nodes from being searched
                        return True
    def bfs(self, start, end, visited, queue):
        if len(queue) == 0:
            # Queue is empty
            queue.append(start)
        currentNode = queue.pop(0)
        print(currentNode, end=' ')
        if start == end:
            # End node found
            return True
        else:
            # Do breadth first search
            for connection in graph.vertexs[currentNode].connections:
                    # Queue all its unvisited neighbours
                    queue.append(connection.name)
            for newNode in queue:
                self.bfs(newNode, end, visited, queue)
    def dijkstra(self, start, end, visited, distances):
      for count, connection in enumerate(graph.vertexs[start].connections):
        # Set each neighbour's distance
        cost = list(graph.vertexs[start].connections.values())
        distances[count] = cost[count]
      smallestIndex = min(distances, key=distances.get)
        if visited[smallestIndex] == False:
          self.dijkstra(connection.name, end, visited, distances)
def setup():
    graphList = {
        # Node number: [destination number, cost]
        0: [[1, 4], [2, 2], [3, 5]],
        1: [[1, 1], [3, 2]],
        2: [[0, 3]],
        3: [[2, 5]]
    count = 0
    graph = Graph()
    for i in range(len(graphList)):
        graph.addVertex(i)
    for arr in graphList.values():
        for i in range(len(arr)):
            graph.addEdge(count, arr[i][0], arr[i][1])
        count += 1
    return graph, graphList
graph, graphList = setup()
def g():
    print("DFS travsersal path from node 0 to node 3:")
    graph.dfs(0, 3, [False, False, False, False])
    print()
    print("BFS traversal path from node 0 to node 3")
    graph.bfs(0, 3, [False, False, False, False], [])
    print()
    print("Shortest possible path from node 0 to 3:")
    print()
graph.dijkstra(2, 3, [False, False, False, False], {0: float('inf'), 1: float('inf'), 2: float('inf'), 3: float('inf')})
What's meant to happen is that after node 2 (the start), the distances dictionary should be:
{0: 3, 1: inf, 2: inf, 3: inf}
This happens successfully, but when it moves onto node 0, the dictionary is now set to:
{0: 4, 1: 2, 2: 5, 3: inf}
What it is meant to be (as it adds up the distances):
{0: 3, 1: 7, 2: inf, 3: 5}
I don't know whats wrong so if anyone can find it, that'll be much appreciated. Thanks!
Specs:
Motherboard: Gigabyte Z97X Gaming 3
CPU: Intel Core I7 4790K
GPU: Gigabyte G1 Gaming GTX 970
RAM: HyperX Fury 16GB
HDD: Seagate ST3000DM001 3TB
SSD: KINGSTON SV300S37A480G 450GB
Cooler: Corsair H100i GTX
Case: NZXT H440 Red
Monitor: DELL U2412M
Keyboard: Gigabyte Force K7
Mouse: Corsair Sabre RGB
A key to debugging
The values are 4, 2, 5...which matches your node 0 inputs (and are exactly 3 off the value, which happens to be the weight from hopping from node 2 to 0).  This would tell me you aren't adding in the values.
I could be wrong (been a while since doing Dijkstra).  Isn't it supposed to build out the list by comparing the minimum's?  You have the shortest index, but outside of the loops where it is setting the distances.  I would think you would need it inside the loop, and checking whether the distance distance is at a minimum (before setting it)...also add the weight of the node to getting to there.
3735928559 - Beware of the dead beef
5 minutes ago, wanderingfool2 said:
A key to debugging
Damm, that's what I forgot. Thanks XD
I don't think so, but maybe I'm wrong.
Thanks anyway!
Specs:
Case: NZXT H440 Red
