So I recently build my own pc and everything runs fine but when I shutdown my computer all my rgb and fans stay on and the cpu red light turns on but when I turn the pc back on the red light turns off plz help.
specs: Amd ryzen 7 3700x
GTX 1660 super sc
NZXT h510 midtower case
2x8gb ddr4 3200mhz ram
cooler master hyper 212 cpu air cooler
Samnsung 860 QVO 1tb solid state drive
msi b450 Tomahawk max
Evga 600w bq 80+ bronze power supply
https://linustechtips.com/topic/1251504-cpu-red-light-on/
48 minutes ago, ShrimpBrime said:
My gather is there's something wrong with the mainboard.
It's not completing the shut down cycle completely.
Have you ever updated the bios on this board?
Yes I have you think I should buy a new main board?
https://linustechtips.com/topic/1251504-cpu-red-light-on/#findComment-14062238
4 minutes ago, YoungPhenom said:
Ok thanks hopefully that fixes the problem
Hope so too!
Take a picture of the mobo serial number sticker.
RMA and Request for a new board, not a repair.
If you get the old one back again, you'll likely have the same issue when it returns.
https://linustechtips.com/topic/1251504-cpu-red-light-on/#findComment-14062615
