I have recently upgraded my motherboard to an asus rog strix b550-f and purchased a new psu to go with it which was a
Cooler Master MWE gold fully modular 750w unit, i noticed the eps splits into both an 8 pin and a 4+4, is it safe to use the 8 pin and then just one of the 4+4 to power my cpu or will i require a 2nd cable.
Thanks
https://linustechtips.com/topic/1251382-eps-help/
Are you sure you have two EPS connectors on that PSU? On the product page it only lists a single 4+4 pin EPS cable.
If you do have two, or one cable that splits into an 8 and a 4+4, you're fine to use the single cable with the 8 pin and one of the 4+4pin connectors.
https://linustechtips.com/topic/1251382-eps-help/#findComment-14060646
Its not really meters, 8 pin provide for continuous load 235-380W (depend who you ask), you will be good with one, if it was mine i was connecting the both connectors, it can split the current in the MOBO side, from the PSU side it will go from the same cable any way.
https://linustechtips.com/topic/1251382-eps-help/#findComment-14060806
from reviews and product page it got 1 EPS cable, if you download the specs.
https://linustechtips.com/topic/1251382-eps-help/#findComment-14060818
