Hi everyone!
Just finished my build with everything working and booting but I can't get the rgb to work. The ram and my motherboard light up but my 5 Coolermaster halo fans remain dark. I have some of them daisy chained and the pump on a single header. The aio came with a rgb splitter a 1 to 3 header cable. So the intake fan has 1 header the pump 1 and the top 2 fans and the rear fan has 1 header.
Somebody has any idea?
Coolermaster Halo fans 5x
Coolermaster ml240 v2
Auros b450i itx
https://linustechtips.com/topic/1251005-coolermaster-halo-argb/
So which of the fans are connected to splitter thats in mobo? As you only have one ARGB header. AFAIK one header can power up to 5 fans. So if I calculate correctly, you have 6 devices (pump and 5 fans). So you really need powered hub to get all of them light from mobo. Or you need to use controller for some of them.
E: Oh, and make sure you have plugged cable correct way.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1251005-coolermaster-halo-argb/#findComment-14061990
