Hi y'all,
I was hoping if you could help me figure out the best way of helping my fiancée upgrade her desktop/gaming rig to get the most of her money. I'm not sure if it would be better to simply upgrade components or just build her a new one (not necessarily using all new parts, but you get my meaning). Her current set-up will be in other details.
Budget (including currency): Absolute max of $US1000, but aiming for under $800
Country: US
Games, programs or workloads that it will be used for:
Fallout 4, Sims 4, Just Cause 3, Planet Zoo/Coaster, Zoom, Microsoft office.
No additional peripherals are needed
She's wanting to improve gaming performance in general, but it was prompted what I think is just a driver issue that I should be able to fix tonight
Current System:
It is an ibuypower prebuilt from ~2014
CPU: AMD FX-6300 6-cores @ 3.5GHz
CPU cooler: A Ziaman(?) fin and fan cooler; I don't really know
Ram: 16 GB DDR3 (2x8GB)(I don't know the speed yet, but will check it and update asap)
Motherboard: MSI 760GMA-P34(fx)(She's already had to replace it once)
Graphics Card: Radeon R7 200 series (probably a 240) 2gb
HDD: Seagate 1TB
Power supply: Soly Tech 400W Non-modular
OS: Windows 10 Home
Things that I know need improving:
More storage
SSD
Graphics Card
My quick well-under budget mockup that needs improving for a new system (MQWUBMTNIFNS for short):
https://pcpartpicker.com/user/fluffythepc/saved/rwMyK8
https://linustechtips.com/topic/1250433-some-advice-required/
$1000 will get you:
- Ryzen 3600
- B550 motherboard
- A 500gb SSD (WD Blue or Crucial P1) plus a cheap 2TB HDD.
- A RTX2060 or RX5600XT
https://linustechtips.com/topic/1250433-some-advice-required/#findComment-14051646
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($204.99 @ Newegg)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  ($109.99 @ Newegg)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  ($53.99 @ Amazon)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  ($59.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI Radeon RX 5600 XT 6 GB MECH OC Video Card  ($259.99 @ B&H)
Case: Cougar MG120 MicroATX Mini Tower Case  ($47.98 @ Newegg)
Power Supply: EVGA SuperNOVA GM 450 W 80+ Gold Certified Fully Modular SFX Power Supply  ($111.10 @ Amazon)
Total: $903.02
Generated by PCPartPicker 2020-09-23 15:42 EDT-0400
https://linustechtips.com/topic/1250433-some-advice-required/#findComment-14051662
4 minutes ago, keeperoffish98 said:
Hi y'all,
Country: US
Current System:
HDD: Seagate 1TB
OS: Windows 10 Home
More storage
SSD
Graphics Card
If you act fast, EVGA b-stock cards are currently going for cheaper then used. https://www.evga.com/products/productlist.aspx?type=8&family=GeForce+10+Series+Family
($199 GTX 1070, $150 GTX 1060, etc) With a 1 year warranty to boot.
You could also take a trip to microcenter if you have one nearby for a CPU price discount. Though I recommend waiting 3-4 weeks for the October release of Zen3 CPUs from AMD.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1250433-some-advice-required/#findComment-14051677
