Budget (including currency): 9,000,000 IDR (611,22 USD)
Country: Indonesia
Games, programs or workloads that it will be used for: mainstream games like apex..
Hi, This is my first post in the forum, Nice too meet you guys :D
so as you can see in the title, im really new in terms pc upgrading like this, and i need help about this,
my pc specs right now is
i3 8100
gigabyte h310m ds2
16gb ram
gtx 1060 6gb
corsair vs450 psu
i want to buy i7 8700 and rtx 2060, and i dont mind if i have to buy a secondhand product.. i heard that my psu might be underpowered and i dont know what to do...
i saw cheap 600w psu called imperion atx 600w with 8 pins that costs like 20$ XD which is cheaper than my current psu that costs 43$ in here.. should i buy that?
oh and also i use a 144hz monitor, so i aim to get higher fps than 60 :)
or if someone have another suggestion build for me i would be happy too :D
https://linustechtips.com/topic/1249790-need-help-in-upgrading/
Welcome to the forums!
11 minutes ago, Castraphie said:
should i buy that?
short answer: no, not in any build unless you are planning to burn something on fire. something like a cx550 is something inexpensive and is a pretty solid unit.
you could also go with a rx5600xt if you dont plan on streaming as it offers the same performance as the rtx2060 for less. or try to find a secondhand 5700xt for something that has more power.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1249790-need-help-in-upgrading/#findComment-14046031
hii thanks for answering and the suggestion
https://linustechtips.com/topic/1249790-need-help-in-upgrading/#findComment-14046045
