Hello, i am having an issue with random rebooting PC and kernel errors.
A year ago i bought a PC
Asus PRIME b450M-K
RX 5700 XT
Patriot Viper4 Series 16GB KIT DDR4 3200Mhz CL16
Ryzen 5 3600
PSU will not be an issue as i tried 3 PSUs and issue still persist.
Before i start, PSU is not an issue as i tested 3 PSUs. SSD is not an issue as well as i tested it in my laptop and it Works just fine.
Basically there is no overheating, no errors. I tried GPU and CPU stress tests and they went perfectly well. I tested my RAM using MEMtest86 and it had 0 errors.
I also tried resetting CMOS, upgraded BIOS, reset bios to default, change power plans, turn off automatic restarts after updates. i tired EVERYTHING and the issue persists
My PC is perfectly clean and i take good care of it. I tried taking everything out and putting it back again.
I am still getting random Kernel 41 random reboots when nothing leading up to it. It just happens.
Kernal 41 errors started 6 months after i bought this PC and it happend exactly 43 times since then.
I am planing on buying new motherboard but first i need to know if it can help.
I am really desperate, can anyone help me please ? Thank you
https://linustechtips.com/topic/1249229-kernel-41-issue-random-reboots/
