So i took out my amd ati radeon 4800 hd series because i thought it needed cleaning....then after pluging the 8 pin connector and pci e slot, i have no video in my monitor and my pc doesnt recognize that i have plugged a graphics card, also the gpu is very loud and i hear it blowing a lot of air...help please
Thanks!
https://linustechtips.com/topic/1248936-i-need-help/
Howdy and welcome :)
There’s a lot of undefined here. “Cleaning” can take many forms. Also just because something looks like it’s plugged in doesn't mean it’s done correctly.
one possibility might be turning off the machine and reseating everything to make sure it’s correctly in there.
What in particular was done in this cleaning may also have an effect.
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14038967
Hi thanks for answering so being honest i just took it out and sprayed some contact cleaner on the pci e slot and the gpu pins. Im pretty sure i plugged everything how it was before..btw what are the plugs on top of the gpu for?
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14039012
Plugs on top of the gpu could be for additional  power (if the gpu is unpowered that could answer a lot) a card can get some power from the pcie slot but for most it’s not enough so there are additional power cables run from the PSU to provide additional power. there is sometimes also a pin set that is for multiple card use (something that is rarely done these days) Nvidia used something called SLI and AMD used something called crossfire, but their function was similar.
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14039031
Yeah that isnt it i dont have that crossfire... i just dont know what to do im confused it was ok...but there was a power outage and i had it on...and then the pc wouldnt power on so i took out my cpu and gpu and plugged them back. Pc works fine with the integrated card.
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14039060
Power outage can produce power surges.  Did you have a surge protector power strip?
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14039067
22 minutes ago, lion8079k said:
No i dont, its an old graphics card so its probably not working anymore i guess
A power surge can take out lots of things.  Maybe out the PSU then maybe random things attached to the PSU (which is everything)
https://linustechtips.com/topic/1248936-i-need-help/#findComment-14039444
