wait for haswell do a build around the new hardware rather than blowing $2.5-$3k on a build that will already be outdated. also next gen nvidia's/ amd gpu
Technically once you get the haswell and nvidia and amd its outdated. If you cant wait then build one now but if you can wait
https://linustechtips.com/topic/12489-i-need-help/#findComment-132887
Waiting for Haswell at this point is probably a good idea, but aren't the prices sort of already available on the new processors/motherboards?  If not, you can probably guess them, which leaves the budget open for the other things he needs: monitors, keyboards, mouse, headset.
you could probably also pick out a case and stuff.
And Green Theme probably means you are going Nvidia?
https://linustechtips.com/topic/12489-i-need-help/#findComment-132896
