Hello everyone,
I have one quick question.
I have order this RAM: https://assets.website-files.com/5cdb2ee0b102f96c3906500f/5ed95dab4ab04f0d10168d75_PVB432G360C8K Sku Sheet_ 060320 Copyable.pdf
This is my MoBo: https://www.asus.com/Motherboards/ROG-STRIX-Z370-G-GAMING/
I am planning on overclocking so what max voltage do you recommend for this RAM?
Thank you in advance.
https://linustechtips.com/topic/1248757-max-memory-voltage/
3 minutes ago, ShrimpBrime said:
Hey thanks Gloop.
This kit is low end at this timing set
18-22-22-42 are horrible timings.
I'd be surprised if this kit will do it's rated frequency on a Gen 1 board and assuming Gen 1 Zen processor.
extra voltage probably won't help the situation....
He uses Intel Z370 board.
https://linustechtips.com/topic/1248757-max-memory-voltage/#findComment-14037632
2 minutes ago, Deli said:
He uses Intel Z390 board.
Lol, I just noticed that. thank you.
StriX-Z370 actually, not 390....
Still doesn't make the kit of memory better.
He'll have the advantage of a decent memory controller.
B-Die would be the way to go, but for overclocking rather a 16GB kit over a 32GB kit.
https://linustechtips.com/topic/1248757-max-memory-voltage/#findComment-14037634
1 hour ago, klosarmicko said:
Here are the end results:
PATRIOT 32GB Viper 4 Blackout DDR4 3600MHz CL18 KIT PVB432G360C8K is absolutely horrible. Increasing the voltages couldn't help lower the timings below 18-20-20-40. My HyperX Predator 2x4GB 3000 MHz 15-15-15-30 scored 6% better FPS in all games tested.
So you were right and I am immediately selling this kit.
I've bought today locally XPG Spectrix D41 RGB 16GB Kit (2 x 8GB) 3600MHz 17-18-18 by default for 94 EUR. Best I could get from it is 15-15-15-30-330 1.45V. Quite refreshing going back to b die. It gives the same performance as already mentioned HyperX, so seems like my games don't care about additional 8GB or 600MHz.
I will stick with this XPG RAM for now.
Thanks for the help. :)
Haha, yeah. B-Die is nice to clock with. Glad your rockin again! :)
https://linustechtips.com/topic/1248757-max-memory-voltage/#findComment-14065223
