2 minutes ago, MadeByGKT said:
A friend of mine wants a gaming laptop that'll run vr and is affordable. No budget but preferably the cheapest possible and runs smoothly, thank you.
It depends where you are, what I will say is for VR get a laptop with a Nvidia card, simply from my own experience with my Vive and my laptop with an RX560 the gpu switches doesnt really work. You will also want to decide what VR headset you are getting because they will decide what output you will need.
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/1248033-a-friend-needs-help/#findComment-14031295
He says he's cool with whatever vr headset and laptop combo works the best.
https://linustechtips.com/topic/1248033-a-friend-needs-help/#findComment-14031315
without any other info to go on for budget or needs,
- Oculus Quest 2 (coming out very very soon)  https://www.oculus.com/quest-2/
- 10ft USB-C to C cable (assuming backpack laptop use with the headset, otherwise try to find a 25foot) https://www.amazon.ca/Fasgear-Charge-Delivery-Transfer-Compatible/dp/B083JQR7TR/ref=sr_1_12?crid=KEQMFQCZQEDI&dchild=1&keywords=usb+c+15ft+cable&qid=1600368254&sprefix=usb+c+15%2Caps%2C205&sr=8-12
- Maingear Vector maybe for the laptop, it's cheap but still has an rtx 2060 for running VR at decent frame rates. https://maingear.com/vector/
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1248033-a-friend-needs-help/#findComment-14031468
