I recently purchased a new monitor ACER Nitro VG270UPbmiipx Quad HD 27" LCD Gaming Monitor - Black. The man attraction for me was the Free sync technology to reduce stuttering and tearing in game. However I don t seem to be reaping the benefits from it and I dont understand why exactly.
Many of the games I have tested appear to be very stuttery, where as they didnt on my old 1080p monitor at the same frefresh rate of 144hz. I have tried a number of games and changed the settings and more often than not i still encounter stutter. I have been using MSI afterburner to monitor my system usage to rule out CPU/GPU bottleneck and temp throttling. Again though I am having issues in games that ran fine on my previous monitor and the upgrade to 1440P has not seen a noticeable increase in temps/usage.
The Display port able I am using is a Snowkids 4K DisplayPort Cable 2M (DP to DP Cable),DisplayPort to DisplayPort Cable (4K@60Hz,1440p@144Hz) High Speed Nylon Braided DP Lead Supports for
HDMI is a standard 2.1 HDMI
I was previously using the most up to date driver on AMD panel but i have reverted back to 20.4.02. Any advice would be greats as I am at my wits end trying to figure it out.
System is
5700xt red dragon
3600 Ryzen 5
16GB ram
SSD storage
Game examples:
VAMPYR- CAPPED at 60 by engine
DP-Monitor RFR 144Hz, Monitor FS ON, AMD FS ON, AMD game FS ON, ingame Vsyn off- STUTTER- NO TEARING
DP-Monitor RFR 144Hz, Monitor FS ON, AMD FS ON, AMD game FS OFF, ingame Vsyn off- STUTTER- NO TEARING
DP-Monitor RFR 144Hz, Monitor FS ON, AMD FS OFF, AMD game FS OFF, ingame Vsyn off- STUTTER- NO TEARING
DP-Monitor RFR 144Hz, Monitor FS OFF, AMD FS OFF, AMD game FS OFF, ingame Vsyn off- STUTTER- NO TEARING (strange as nothing is stopping the monitor from tearing at this point)
DP-Monitor RFR 60HZ, Monitor FS OFF, AMD FS OFF, AMD game FS OFF, ingame Vsyn off- TEARING
HDMI- Monitor RFR 60Hz, Monitor FS ON, AMD FS ON, AMD game FS ON, ingame Vsyn OFF- STUTTER- TEARING
HDMI- Monitor RFR 60Hz, Monitor FS ON, AMD FS ON, AMD game FS ON, ingame Vsyn ON- STUTTER
AC ODYSSEY- 60FPS CAP in game to reduce distance between high/low fps
DP-Monitor RFR 60Hz, Monitor FS ON, AMD FS ON, AMD game FS ON, ingame Vsyn off- STUTTER- TEARING
TOM C GHOST RECON
DP-Monitor RFR 60HZ, Monitor FS OFF, AMD FS OFF, AMD game FS OFF, ingame Vsyn ON- STUTTER
https://linustechtips.com/topic/1247911-freesync-issues-advice-needed/
