Mini ITX Build! Help
Solved by Aereldor,
1 hour ago, Ricardo Duarte said:
The parts you have picked out are pretty much perfect. The i3 is somewhere between a Ryzen 3100 and a 3300x but with integrated graphics. I would buy those.
These people telling you to buy Ryzen have no idea what they're talking about, you literally won't get a display output without a GPU unless you buy one of the Ryzen 'G' APUs, which sort of suck anyway.
