ran into a problem with my port forwarding
i did all of the port forwarding as it should be but my minecraft server is not showing as online
i did both tcp and udp protocols and tried doing them separately but it didnt work
the port is correct and the ip of the pc is correct
ive tried doing this from another pc and it still didnt work
also tried enabling java though firewall - didnt work
any ideas?
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1247444-port-forwarding-again/
Steps to check:
1. Some routers have a firewall separate from the port forwarding, if so: are both configured?
2. Try to connect from a pc from within your network. If that works, then you did not do the forwarding correctly
3. Disable the firewall on the PC hosting the minecraft server completely. If that works, check your rules.
4. Throws hand in the air and curse at sky.
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026159
7 minutes ago, Dujith said:
Steps to check:
i can connect froma  different pc with 'direct connection' to my pc's ip address but i cant connect to the local ip address
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026181
1 minute ago, PatrikYT_98 said:
what router are you using?
Sagemcom
with my old router i didnt have this problem
the second i port forwarded, it worked
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026185
Since thats the same. Direct connection = local ip address i think you mean something else?
Just now, HardStroke said:
Sagemcom
Which model?
Also plz follow the steps and tell the result per step, this feels like your just randomly trying to bash things to get it to work :D
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026187
Which model?
my pc's pi is 1 thing and the local ip that im giving to my friends is something else
disabling the windows firewall did nothing, ive already tried it before as well as letting anything thats java related through so i know that its not the firewall thats causing this problem
like i said, i can connect from another pc only if i put in my pc's ip but i cant connect with the ip that im giving to my friends, the local ip not the pc's ip
model is sagemcom fast5657il
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026192
Local ip is your internal IP, most likely something like 192.168.1.x
Your external IP is what you give to your friends. But thats splitting hairs.
So step 2 is answered: You can connect from your internal network to the PC, just not from the outside. That rules out the firewall on the minecraft server.
Something in your router is not setup correctly, like i said. Some routers have a separate section for firewall and port forwarding.
Also, you are sure you have the correct external IP? changing routers can cause the ISP to change external IP
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026209
looked my ip on google and verified it at the router's settings - same ip
like i said, i cant connect with my external ip so my friends cant connect
also, when i see the servfer in the servers list it doesnt show up as online
there are my firewall settings on my router:
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026236
maybe 'DMZ' has something to do with it?
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026247
“You keep using that word. I do not think it means what you think it means.” -Inigo Montoya
DMZ is Demilitarized zone, a network segment between the external network and internal network and completely open.
This is usually not available on a consumer router.
What u mean is a DMZ-Host, That would be a host that receives all the open ports besides the ones being forwarded to a specific host
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14026871
saw onlinethat it has something to do with port forwarding so idk
i fixed it somehow
the server is suddenly working its just not showing up as online, weird shit
https://linustechtips.com/topic/1247444-port-forwarding-again/#findComment-14027162
