My 3600 with a custom loop spikes into the 70's
I think these chips are just terrible at transferring the heat to the top of the cpu. The temps spike wildly in less than a second, to me that means there is just not enough conductivity between the top of the cpu and the insides.
https://linustechtips.com/topic/1247310-3600x-temps/#findComment-14025324
Stock or OC?
Mine OC 4.4GHz all core barely hits 75C with AIDA64. Also using a 240mm rad. If I run it stock. It stays below 65C.
https://linustechtips.com/topic/1247310-3600x-temps/#findComment-14025360
  • 2 months later...
