Wow!  Where in the World is Carmen San Diego.  Talk about a LONG time ago.  There was another WinME game back in the day that was a really neat game but dang if I can't remember the name of it.  Bummer.  HAA!, Now I got it.  The name of that game was Rendezvous with Rama.  Wow, sure would like to get my hands on a copy of that and then figure out how to play it.  There were two versions, a DOS version with game interaction nothing more that conversation in DOS and then the WinMe version that actually had color graphics with a guy escorting you around explaining things and giving you puzzles to solve.  The entire game took place inside an extremely large space bound cylinder with creatures living in it that you had to convers with and other stuff.  Man, that was a LONG time ago, for sure.  Thanks for the memories, I'm not dead yet after all.
Good Luck
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14022572
Is it 32bit win xp? 32bit systems can natively run dos programs.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14022586
Good Luck
Thanks yeah it's hard to figure out all the versions
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14022917
1 hour ago, matt915 said:
How? I guess I tried just putting it in and forcing it to run and nothing that's why I used dos box.
Copy the data from the disc and try. It just runs like a normal 16 or 32bit program.
Bios database
prior build:
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14023113
17 minutes ago, matt915 said:
Copy the game to my hard drive? Is that legal?
Do you own it? As long as you dont share it, yes.
Bios database
prior build:
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14023735
1 minute ago, matt915 said:
Yeah your right I copied it and apparently was able to install it now how I get it to run dos box?
You dont need to, just run the game exe from files.
Bios database
prior build:
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14023755
OK, now fing the directory C:/Dulex, then doubleclick on Carmen.exe
Bios database
prior build:
https://linustechtips.com/topic/1246983-dos-game-help/#findComment-14023780
