As we all know, the 3000 series are coming out soon I'd like to purchase the founders edition or ROG STRIX 3080. I'm wondering if it would even fit my motherboard, I currently have a XFX RX580 (Length: 269mm); It's basically touching it. There's a connector to the right (big bottom, right square) that I think will be in the way, but I'm not sure and need to make sure.
MSI B450M Bazooka: https://www.msi.com/Motherboard/B450M-BAZOOKA
Founders Edition 3080 Length (In mm): 285mm
ROG STRIX 3080 Length (In mm): 319mm
CASE: NZXT H510 ELITE MOTHERBOARD: ASUS ROG Strix B550-F Gaming (WIFI 6) CPU: AMD Ryzen 5 5600X 4.7GHz (ZEN 3COOLING: Arctic Freezer II AIO 280mm RAM: 32GB Corsair Vengeance RGB PRO 3200MHz CL15 GPU: NVIDIA RTX 3080 Founder's Edition PSU: Thermaltake RGB 850w 80+ Gold STORAGE: SSD Samsung 860 EVO 250GB // M.2 NVME WD BLACK 1TB // M.2 NVME Samsung 970 EVO 1TB // HDD Seagate 2TB OS: Windows 10 Home x64 Bit MONITORS: LG 27GN850-B @144Hz 1440p // Acer XF270H @144Hz 1080p MOUSE: Razer Viper Ultimate Mercury White KEYBOARD: Razer Huntsman TKL (w/ Razer Mercury White Keycaps) HEADSET: HyperX Cloud Flight
https://linustechtips.com/topic/1246397-will-it-fit/
as URANIUM said, motherboard components normally isnt an issue unless a connector is right behind the GPU that's sticking up
GPU length would normally dictate whether a casing will fit it or not, so check your casing's GPU length clearance.
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1246397-will-it-fit/#findComment-14017994
