Long story:
I was running my PC with 16Gb(2x8Gb kit) ram from corsair at the beginning with XMP (3600CL18) then oc it with ryzen calculator to 3600CL16 1.4V trfc592(lower didn't even boot). Later on, I decided to upgrade it so I added same corsair 16Gb kit. My oc didn't work so I just enabled XMP and make a mistake that I didn't check it because I was thinking that XMP should work. After a week my windows become corrupted and learned that even same kit is not guaranteed to work together at XMP speeds. Finds out that one kit is micron E-die second is samsung B-die, I raised the voltage from 1.35V to 1.4V, disable power down mode, enabled gear down mode, and tested it in memtest86 - 0 errors. It was running fine for like 4-5 weeks but I decided to update the bios of my MSI X570-a pro(big mistake) few minutes after booting into windows my chrome tab crashed then I got BSOD and knew something was wrong with memory so I run memtest86 and got A LOT of errors not even after 2 seconds. I checked my settings in bios, clear CMOS, reseeded ram, and still got errors at 3600mhz(default 2133 was working fine). I decided to revert bios to the previous one to find out it didn't fix it, again did the same things. Again I flashed new bios and was checking what is causing it by raising the voltage of DIMM, SOC, then losing timings. After a day I found out that my settings that worked before for weeks was ruining fine but only on cold boot, as soon as I restart or reboot my pc I got BSOD and if it boot to windows then HCI test gives me "Memory error detected Pair xxxxxx does not store values accurately" and then BSOD soon after. What can cause it? I run out ideas on what to check. Pls help.
TLDR:
My ram is stable only at cold boot and is unstable after I reboot/restart PC. help
https://linustechtips.com/topic/1245373-need-help-with-ram/
memory trains properly (i.e. decides its timings during boot) when cold but not after it warmed up, I see this as a sign that the memory settings is only barely stable at 3600MHz. Try forcing 3200MHz with XMP turned on.
Desktop benching:
https://linustechtips.com/topic/1245373-need-help-with-ram/#findComment-14009713
are you able to test it by running a single stick at a time to isolate the sticks? it should be very obvious when the bad stick is in if it even gets past a boot or all the way into windows.
it sounds like a dead stick or dying chip which can't keep up with the 3600mhz, at cold boot the chips are empty until enough data is written but when just restarting depending on your settings the memory will retain most of the data for a faster restart causing the instability.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1245373-need-help-with-ram/#findComment-14009715
Hello and welcome.
Turn off Fastboot.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1245373-need-help-with-ram/#findComment-14009749
Hmmm I think MSI has a feature that will disable memory training, but I can't remember what it's called.  It's in the memory settings I believe.
https://linustechtips.com/topic/1245373-need-help-with-ram/#findComment-14009779
