So I know more info will come out but I'm looking for a 3080 that's a reference design for the new EK waterblocks. No one has released any info really on their cards but I'm thinking people can post here when manufacturers update their info. I don't want to end up buying a card I can't put a waterblock on. Also I'm cardless right now and I'm itching to order it day of release.
DD Rig
9900k OC 5ghz allcore
Custom watercooled 3 - 3x120mm rads(2x60mm,1x30mm) future proofing
Lian Li O11
GIGABYTE Z390 AORUS ULTRA
Corsair Vengence pro 64GB DDR4 3200
EVGA RTX 3080 FTW W/ bits WB
Samsung 1tb 980 Pro
Sabrient 2tb NVME x2
2x2tb Seagate Hybrids
850W Corsair RMx PSU
Plex Server
R7 5700G w/Scythe Mugen 5 Rev. B
Gigabyte B550M AORUS PRO-P
16gb Adata 3200mhz
8 WD Reds
Samsung 1tb 980 Pro
750w Corsair PSU
https://linustechtips.com/topic/1244442-rtx-3080-reference-cards/
Good consumer. buy buy buy!
EK will have a list of GPUs that are compatible with their blocks on their website, as they usually do.
https://www.ekwb.com/configurator/
For example here the ASUS Strix 3080
I'm just trying to stimulate that economy! I'm taking one for the team and doing my part.
I was unaware they had that on their site. I can only assume if they have those Asus cards on their site they will probably make blocks for them. I just don't want to buy a card and end up getting screwed when there is no block for it.
DD Rig
Lian Li O11
Samsung 1tb 980 Pro
Plex Server
16gb Adata 3200mhz
8 WD Reds
Samsung 1tb 980 Pro
750w Corsair PSU
I should add, that most AIB cards seem to use the old 2x 8pin power connector, which automatically makes them non-refernce PCB cards and that the reference PCB this time has an incredibly weird shape. You will probably only find the reference PCB on the reference card and nowhere else.
From what I've heard the Founders card is not the reference design. Nvidia is basically making a custom card for the Founders so they are not considered reference design. The EK block they announced are for the reference design not the founders.
DD Rig
Lian Li O11
Samsung 1tb 980 Pro
Plex Server
16gb Adata 3200mhz
8 WD Reds
Samsung 1tb 980 Pro
750w Corsair PSU
EK confirmed that FE will get a waterblock, so probably nothing to worry about there.
Quote
``Founders Edition cards will get their own specially-developed EK-Quantum Vector water blocks.''
https://www.ekwb.com/blog/did-you-know-the-nvidia-30-series-founders-edition-layout-is-not-a-reference-design/
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
Oh wow...I wouldn't have expected that with the weird PCB design and stupid new vertical connector.
DD Rig
Lian Li O11
Samsung 1tb 980 Pro
Plex Server
16gb Adata 3200mhz
8 WD Reds
Samsung 1tb 980 Pro
750w Corsair PSU
https://www.tomshardware.com/news/bykski-releases-first-waterblock-for-nvidia-rtx-3080-and-rtx-3090-founders-edition-cards
Bykski already has a waterblock for the founders cards. I find it funny the writer on Toms says why would you pay the premium on the founders cards to just waterblock it. Meanwhile the founders cards will be the cheapest cards at launch. According to leaked prices that have surfaces for AIB cards.
DD Rig
Lian Li O11
Samsung 1tb 980 Pro
Plex Server
16gb Adata 3200mhz
8 WD Reds
Samsung 1tb 980 Pro
750w Corsair PSU
Think I’d get a reference card instead of the fe. Simply for board size. Though I may actually like the small board unless the block extends past the pcb.
Though I left the small board stuff in the 660 era.
