Hi all.
New user, so sorry if I’ve posted in the wrong section.
Currently have this rig, but overall it’s getting upgraded in the next few months:
AMD FX8320
MSI 970a-G43 Plus
16gb Vengeance DDR3 1833mhz
GTX780 (non Ti)
Essentially everything is been upgraded to Ryzen 5 3600 with MSI B450A Pro Max and 16gb.
But I’m considering whether or not to change the GPU. I guess that should I keep the GTX780 it’ll likely be a bottleneck.
ive not got a huge budget for GPU, looking in the realm of <£180 (yeah I’m in England).
I’ve been considering at RX580 8gb as can pick them up new at around £150-60. But would it be much of an upgrade from the 780.
What other cards would you suggest?
(1070 seems to be above budget or difficult to find)
(most games I pay are GTA V, Fallout4/76 and Skyrim, but thinking of getting RDR2 if it’s reasonably playable).
https://linustechtips.com/topic/1244381-upgrade-help/
1070 would have been my suggestion. Looking at eBay some have sold for less than £180, and if you're able to push your budget to £200 I think you should be able to get one.
If not, rx580 should offer a reasonable improvement (50ish% from what I can find)
Could perhaps look for a cheap rx590 as well.
If you want to buy new, a 1650 super would offer similar performance to a rx580
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1244381-upgrade-help/#findComment-14001401
10 minutes ago, RuSZ said:
Hi all.
AMD FX8320
MSI 970a-G43 Plus
GTX780 (non Ti)
gtx 1660s costs around 240 dollars which is around your budget
https://linustechtips.com/topic/1244381-upgrade-help/#findComment-14001403
Not thought about the 1660 so good shout. Just had a luck and some seem to fall into budget.
I had previously ruled out 1650 as some posts I’d seen didn’t suggest it was “much” of an upgrade.
I’ll keep an eye out for 1070’s though as that would be preferred.
was partly thinking RX580 as seemed to be a fair upgrade to the 780. Also I’ve never gone for AMD GPUs, so was thinking of a bit of a change.
had this 780 for 5yrs now, originally had it with an i5 that died (and prompted the change to the FX8320)
would my overall build of the following be fairly decent with an 1070, 1660 or 580 depending which I can get at the time? (Ryzen5 3600, MSI B450A ProMax, 16gb 2666mhz)
https://linustechtips.com/topic/1244381-upgrade-help/#findComment-14002850
Given the cards that have been mentioned, the 1070 and 1660 Super should be pretty comparable performance wise to each other, some titles may favor one over the other and vice versa. And both would be faster than an RX 580. If talking a base 1660 (non-Ti, non-Super) then the 1070 would probably edge it out.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
https://linustechtips.com/topic/1244381-upgrade-help/#findComment-14002927
