already have the 2080 ti and the 3700X?
if not, wait for the 3070 and maybe 4th gen Ryzen
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1244262-will-my-pc-bottleneck/#findComment-14000570
29 minutes ago, Jurassicturtle said:
So I just want to know if a ryzen 7 3700x will bottleneck a 2080 ti
I will be useing this computer for blender and gaming ultra settings
No, (or yes? Depends on how you mean it) for 95% of things.  Two of them are some kinds of video production and playing a few types of games on very small monitors at very high refresh rates though.
So more or less not enough info. Very good chance you’re not an edge case, but if you are to answer one would Need to know what sizes of video production and which kinds of games
@Fasauceome has the best suggestion though if it can be followed.
https://linustechtips.com/topic/1244262-will-my-pc-bottleneck/#findComment-14000612
It's depends on the type of game, but generally, the most stress on the CPU comes from handling frames from the GPU, if you're running at 1080p in something like CS:GO and pushing 500fps, yeah, that can put a lot of stress on the CPU, but normally, you're going to be getting a card like this for AAA games at 1440p or higher, and the framerate is just not going to be high enough to significantly tax the CPU. Even if it's a game that actually uses the CPU, the 16 threads on the 3700X are going to be plenty.
However, unless you already have the 2080 Ti, you should wait for the 3070. Same or slightly better performance for a *much* better price.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1244262-will-my-pc-bottleneck/#findComment-14000619
