Hello LTT fans,
I recently just build my first pc a week ago, on the 1st September and for some reason my mic isn't working. I have updated all my drives and even rednloaded them but seems it dosen't fix the problem.
BTW i use a mic that is attached on my headeset
Please help i really want to call on discord with my friends so i can clap noobs online, thanks :D
P.S The headset i use is the Hyperx Cloud Stinger Core
https://linustechtips.com/topic/1244036-need-help-with-mic/
Check if Windows allows access to the microphone. There's a weird setting hidden somewhere in Windows 10, I'll try to find a guide. BRB
Edit:
Found a quick guide
TLDR:
Settings -> Privacy -> Check that the device has microphone access and that apps have access to the mic as well
Edited by myselfolli
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/1244036-need-help-with-mic/#findComment-13998606
Check that you have set your microphone set as the default recording device as described in Solution 2 of the guide I linked.
Also, how is your mic/headset connected? From what I found online, it should have dual 3.5 mm audio jacks. Please make sure they are both plugged in correctly.
https://linustechtips.com/topic/1244036-need-help-with-mic/#findComment-13998628
