My system shuts down every time I try to access my storage drive. Simply opening it in file manager causes my whole computer to turn off. It is definitely that drive because under normal operation like browsing the web or even gaming my pc is totally fine. It may be infected because I read online that viruses can cause the system to shut down and I do think that is my issue because I tried to run malwarebytes and even that triggered a shutdown. Any info helps thanks in advance!
https://linustechtips.com/topic/1242183-hard-drive-causing-system-shutdown/
Now that's interesting. Try running chkdsk and check for damaged sectors. Run it with the parameter /f, it will repair them before the next boot.
CPU: Intel Core i7 8086K, Delidded with Der8auer Custom Nickel-Copper IHS and Coollaboratory Liquid Ultra CPU Cooling: Scythe Ninja 5 with Thermal Grizzly Kryonaut Thermal Paste Motherboard: ASRock Z370 Taichi RAM: 2x16GB Kingston Predator DDR4 3200 MHz 15-17-17-36 GPU: Gainward RTX 2080 Phoenix GS with Raijintek Morpheus II Core Black Heatpipe VGA Cooler, Thermal Grizzly Kryonaut Thermal Paste and 2x Scythe Kaze Flex PWM 120mm fans Case: SilentiumPC Regnum RG4T Pure Black TG Storage: Samsung 960 EVO 250GB, Samsung 970 EVO 500GB, Seagate ST4000DM 4TB HDD, Toshiba HDWD240 4TB HDD PSU: SilentiumPC Supremo FM2 Gold 750W Case Cooling: 6x Scythe Kaze Flex PWM 120mm fans Keyboard: Corsair Strafe Mechanical Keyboard Mouse: Trust GXT845 Tural Display: Sharp LC-50LD265E Operating System: Windows 10
