Need help with clean install.
Solved by Cacao,
Well there is a program you can use to find the CD key on your system, then you could just download a win 7 ISO and use that CD key. Not really the recommended method though, your best bet would be to find the original CD.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
