Every so often when I turn my pc on it goes to the american megatrends page. Everytime it says the same things, "WARNING: Please back-up your data and replace your hard disk drive. A failure may be imminent and cause unpredictable fail."
I use a Cruicial 500gb M.2 SSD, not a hard drive. Nothing Has happened to my SSD yet. How do I solve the issue?
https://linustechtips.com/topic/1241430-booting-issues/
Do you have any other drives plugged in?
Ryzen 7 5800x, eVGA GeForce RTX 3060 Ti XC 8GB, Kingston Fury 32GB 3200 MHz, Samsung 970 EVO Plus SSD 250GB M.2, 3X Seagate 1TB HDD 7200Rpm, 2TB Seagate HDD, Cooler Master V 750W 80PLUS Gold Full Modular Power Supply, CoolerMaster N200
https://linustechtips.com/topic/1241430-booting-issues/#findComment-13978970
3 hours ago, GubbinGameDev said:
I have no other drives plugged in, the only drive is the ssd.
Use something like CystalDiskInfo to see if any drive health issues pop up.
How old is the drive? If it's not that old it's probably just a fluke with how the motherboard is reading the drive health status. You might be able to just disable SMART reporting for that drive in the BIOS. Not sure if that will prevent it, but would be worth a try AFTER you verify there isn't actually a drive health issue.
Looks like something more common like HWinfo64 will also show drive SMART status.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1241430-booting-issues/#findComment-13980270
Crystal Disk info says my drive is completely healthy. I will try my best to disable smart reporting (I have no idea how to do that)
https://linustechtips.com/topic/1241430-booting-issues/#findComment-13981625
