Anti-Leak thing
20 minutes ago, Marcel91 said:there are some that says that they have anti leak while some others don't. Are there any real differences or benefits with having them?
you can bet your ass that no manufacturers make their AIO to leak, so i wouldn't look too much into it
20 minutes ago, Marcel91 said:Is it worth it?
if you mean the "anti-leak" statement, i wouldn't worry too much about it
if you're asking if AIO are worth it, i would say maybe.
AIO are normally more costly than air, so if you could go air cooling and bump up a CPU/GPU tier, it's definitely not worth it.
there are also more risk and point of failure involved. Personally would just go with air cooling.
but they do look better for some people, and it's easier to access RAM and such. and a top tier AIO performs better than aircoolers. so it's up to you
20 minutes ago, Marcel91 said:Is leakage a leading point of failure or are there other parts of the AIO that will fail first before any actual leakage?
this is entirely RNG, if you're not comfortable with having a leak, dont get an AIO
it's not common to leak, but it does happen. and when it does, it's normally catastrophic failure
I've seen pump fails and leaking just about as equally much while dwelling here, maybe more pump death
seen too many components die due to watercooling in general, enough to deter me away from it.
