Hey Guys,
I built a computer a few months ago now and this time I decided to go for Ryzen. I love my system, it's a huge upgrade over my old 6800k setup. But there is an issue I am having. I CANNOT get my ram to boot at the stated speeds on the the box. I am stuck at 2133mhz.
Things I have tried:
  • If I go into the motherboard settings and set the board to D.O.C.P. I immediately boot into safe mode.
  • I attempted to adjust the dram voltage up in .01 increments from 1.35 (spec) to 1.40 while leaving DOCP settings the same (still boots safe mode)
  • I have tried reordering the sticks (put slot A1 into B1 and visa-versa)
  • I have the ram installed correctly according to the manual (in the correct slots)
  • I confirmed compatibility on the ASUS website for my specific kit of RAM
I know that this should work and to further prove my point LTT just put out a video with the same CPU as me while running an RGB g.skillz 32gb 3600mhz kit. I feel I am missing something or once again I have really bad luck with the silicon lottery. I received help on the forums before when picking my parts for this build and so I look forward to any help I can get this time around too. I am beyond frustrated at this point and have no idea what to do but I should be able to get above stock speeds on this kit. Thank you in advance!
P.S. Worth mentioning I do use Ryzen Master to overclock the cpu, is it possible there is a conflict between Ryzen Master and the motherboard settings? I have attempted the RAM overclock with the CPU at stock speeds and overclocked slightly with the same safe mode boot issue.
Here are my specs:
AMD Ryzen 3900x
ASUS Hero VIII Wifi x570
G.Skillz TridentZ (32gb DDR4, 3600mhz, 2x16gb sticks) (f4-3600c16d-32gtznc)
2x 1tb nvme SSD's
2x 2tb HDD (Raid 0)
https://linustechtips.com/topic/1240929-ram-help/
Apparently not, because on Asus boards it's A2 and B2 first.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1240929-ram-help/#findComment-13974216
3600Mhz is not guaranteed to work with all CPUs. It is technically an OC.
You can try bumping your soc voltage up to 1.1V or 1.2V.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1240929-ram-help/#findComment-13974244
Technically, yes, but any Zen 2 chip and an X570 board is going to be able to at least handle 3600Mhz.
https://linustechtips.com/topic/1240929-ram-help/#findComment-13974259
I have a masters degree, but apparently cannot read lol. That immediately solved the problem. Thank you Chris, much appreciated! I can't believe I misread that. Good old confirmation bias at its finest. All my previous motherboards needed A1 and B1, so that's what I saw when I read it.
https://linustechtips.com/topic/1240929-ram-help/#findComment-13974397
Happens to the best of us. Glad it fixed your issue.
https://linustechtips.com/topic/1240929-ram-help/#findComment-13975408
