I bought MSI MAG Coreliquid 240r day a ago. I overclocked My Ryzen 5 3600 to 4475MHz 1.375v and its stable on Asrock Steel Legend B450. on idle My cpu about 41C and keeps peaking to 51C every couples of second and on gaming also 53C to 61C, on CPU stress test the temps are stable and average of 72C and peaking 75C once or never at all. is this normal with liquid cooling because this is my first time I use liquid cooling, or something else is wrong. or  it has something to do with precision boost of AMD 3rd gen, because I only change the frequency and voltage on bios ONLY.
Whats the problem ?
https://linustechtips.com/topic/1240202-peaking-temps/
Yes these temps are fine, both idle and load temps are, and either way idle temps do not matter, load temps do..
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1240202-peaking-temps/#findComment-13968985
exactly the same with my 3600 completely stock under a d15s, seems like thats just how it be. itd be interesting to know why as the idle power draw, though it seems high (30-35w), is constant and doesnt spike at the same regular intervals
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1240202-peaking-temps/#findComment-13969003
