So when i record a video with obs and i want to edit it with adobe premiere pro every time when i import it to adobe a red frame appears.I want to mention that i don't have this problem when i record with Amd software. I also tried some fixes for adobe but nothing worked out.
Operation system:Windows 10
Premiere Pro build:13.0
Source footage format is mp4
Pc specs:Amd ryzen 7 3700x
Radeon RX 5600 XT
https://linustechtips.com/topic/1239858-premiere-pro-red-frames/
Quote
This issue is not a failure of the export process, but rather an indication of a problem with the way the source footage was encoded. When Media Encoder encounters frames that cannot be decoded, it inserts red frames in their place.
Source
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
3 minutes ago, iLostMyXbox21 said:
thank you for the help and this was the problem but i still don't understand one thing:on  the obs i used the same encoder as the amd software yet one is working the and the other one is not,i had to use on the obs the AVC encoder instead of the HEVC for some reason
