Hello,
I am in need of a new pc and was considering a laptop instead of a desktop. The choices and pricepoints are just overwhelming and I need this forums help.
Specs I am looking for:
i5 proccessor
16 GB RAM
GTX1650
nvme 512GB SSD
Good to have but isn't a must:
HDMI port
touchscreen( I like it a lot when I tried to use it on other laptops but I am aware it brings up the price significantly)
Any reccomendations help, thanks!
https://linustechtips.com/topic/1237726-laptop-help/
20 minutes ago, jaslion said:
Why do you need a laptop instead of a desktop?
As I student I am quite more mobile than a I was as a highschooler and I just like the idea of getting work done anywhere. (Although I am not going places since this quarantine crap, but for futureproofing)
https://linustechtips.com/topic/1237726-laptop-help/#findComment-13950432
What does it have to do and what's the budget?
https://linustechtips.com/topic/1237726-laptop-help/#findComment-13950515
2 minutes ago, Quantzer said:
CAD software( Solidworks, Autocad, Catia), little bit of video editing and little bit of games(league of legends and crap like that)
And what is the budget? I can recommend you 2k devices or cheap and not great to bad 600$ devices in that range.
https://linustechtips.com/topic/1237726-laptop-help/#findComment-13951074
