Microphones don't work
Solved by kirashi,
6 minutes ago, snailAtSpace said:I tried 2 microphones on my new PC, and they both don't work. No sound is picked up. The microphones are USB and PnP. I tried them both on my friend's PC and they
Assuming your PC either installed the drivers for your microphones or soundcard on the motherboard, have you checked your privacy settings?
https://www.howtogeek.com/395296/fix-my-microphone-doesnt-work-on-windows-10/
