Hello! I have been currently looking for a laptop but I'm having complications finding one.
I'm on a $850 budget and I plan to use the laptop for Art, Music Production/DJing, and mid tier gaming (meaning I won't be using it for triple A games but mostly games like Minecraft and and low polygon games)
I'm mostly looking to buy one during Cyber Monday but is there any laptops I should look out buying?
Thanks!
https://linustechtips.com/topic/1237630-laptop-buying-help/
Hello, I recently found This resource  over on Reddit. It compiles a lot of the recent gaming laptops.
You'll want to be looking out for a laptop with a stronger CPU/RAM for music production in particular.
Lenovo Legion 5 would be a good pick. It's got a good CPU, decent graphics card and fits your budget quite nicely.
Midori:
Specs: Intel i5 4690K | Asus Strix GTX 1070 |  2x4gb Corsair Vengeance DDR3 @1600MHz| Samsung 850 Pro 250GB | WD Blue 1TB | EVGA Supernova G2 750W | NZXT H440 Black/Green
Cooling:|2 Stock NZXT Case fans | 2 Noctua F-A14 FLXNoctua NF-P14S-1200 |
Peripherals: Corsair LUX RGB K70 Silent| Corsair RGB Sabre | Audio Technica M40X
OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/1237630-laptop-buying-help/#findComment-13949766
