Budget (including currency): 650 euro's (776 usd)
Country: Netherlands
Games, programs or workloads that it will be used for: Forza series, flight simulator 2020, planet coaster, game developping and graphic design
So my birthday is coming up this week and I have decided to treat myself to a new pc. This will be the first machine I am going to build from scratch so I wonder if someone could check my build for incompatibilities and or things I could do differently. The attached PDF has all the parts listed.
I appreciate all the help I can get, and if some choices aren't clear I am happy to explain.
Amazon.nl-winkelwagen.pdf
https://linustechtips.com/topic/1237457-first-custom-build-compatibility/
4 minutes ago, Owie9go said:
May I ask what is bad about the psu? and do you have a recommendation for motherboard?
2 minutes ago, PatrikYT_98 said:
psu is good and powerfull enought but get a better motherboard with better vrms and vrm cooling like ASRock b450M PRO-4-F i used 2 of them and they work perfectly! i recommend that board its cheap and better than the asus cuz it has better vrms and vrm heatsinks
Not the power. It’s powerful enough. It’s just not reliable enough
If you go with the board mentioned, you may have to update bios, with a different am4 cpu, so I would say stay away unless the vendor says Ryzen 3000 ready
36 minutes ago, YT_DomDaBomb20 said:
I'd rather not risk having to update the bios. So I think I'll just buy the MSI motherboard. Also, isn't a 1660 super to much for a 3100?
No, a 3100 can handle it, it has 4c/8t on zen2, it’ll be fine
