Evga P55 Le Motherboard Won't Stop Having Issues...
Solved by ryan9298b2,
That is a very cool build! Try taking the fan covering the pci slots out and putting the card in the 6th slot from the top. Power off the computer and unplug the power supply before moving expansion cards, or anything else that directly connects to the motherboard for that matter. ;)
You could probably remove some of those fans, cable manage a bit, and you would have an awesome and quiet gaming system. I noticed in your video that it was a bit loud, but that is fine if i doesn't bother you. ;)
