PCI-E Wireless N Card with Black PCB?
nukem
im fed up with usb wifi adapters, the speed when downloading is never consistant, unfortunately i cant run an ethernet cable to my pc.
Anbody know of a Good PCI-E Wifi card (doesnt need to be AC) that has a black PCB? i really dont wanna put a card with a green pcb inside my build.
PC: Corsair 900D | Corsair AX860 | Maxmius VI Hero | i7 4770k | Corsair H100i | 16GB Corsair Vengeance Pro 2133 | Sapphire Radeon 7950 | Samsung 840 Pro 256GB | Win7 X64
HTPC: Silverstone GD05 Black | Corsair VS350W | AMD A6 5400K | AsRock FM2A75-PRO4-M | Corsair Vengeance 2x4GB DDR3 1600 | Samsung 840 128GB | WD Black 4TBx2 | Leadtek Winfast DTV2000DS | LiteOn BD\DVD-RW Combo | WIN7 x64/XBMC
http://www.amazon.com/Gigabyte-GC-WB300D-Exclusive-Bluetooth-Motherboard/dp/B0081Y0Y4E?tag=vglnk-c1001-20
http://www.mightyape.com.au/product/Gigabyte-Bluetooth-40--AC-Wifi-PCI-E-Network-Card/21993377?utm_source=myshopping.com.au&utm_medium=cpc&utm_campaign=shopping_comparison
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
thank you
PCIE Wireless adapters work great honestly! Paired with a good router I never disconnect or anything and my speeds are really good.
Just looking at that Gigabyte unit, I see no reason you couldn't chuck an Intel AC chip in there.
i just bought a gigabit ethernet adapter kit for $50. apparently they r good just need to setup when i get the time.
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
I have one, it works well. I thought that it was interesting they used a mobile wireless nic, the potential for upgrade is a nice benefit.
