Budget (including currency): $1500
Country: USA
Games, programs or workloads that it will be used for: Gaming, Day to day use
I'm going to be building a new PC soon and i need help
my budget is around $1500 could go a little bit over
so i was looking at the AMD Ryzen 9 3900X and the AMD 5700 XT
could go with Intel and Nvidia
https://linustechtips.com/topic/1236008-pc-build-help/
Country: USA
If it’s mainly for gaming, intel is a better option. 10700k will give you more FPS, and I would wait a few weeks for nvidia 3000 series and either get something like a 3070 or a good deal on a 2080 possibly.
https://linustechtips.com/topic/1236008-pc-build-help/#findComment-13936421
I disagree. You will be paying more for an Intel setup, which could be the difference between a better gpu if you go AMD. Also if the op is aiming for 1440p then there won't be much in it if he is happy with a 5700XT or similar.
https://linustechtips.com/topic/1236008-pc-build-help/#findComment-13936446
I mean, I don’t think a 10700k is needed, but if he was planning on a 3900x... a 10600k is a great option, and priced well. That plus a 3070 would be a fantastic choice. 1440p depending on refresh rate, a 3070 would be perfect, a bit overkill but perfect. I have a 1080 @ 2050 in my secondary PC, at 1440p 165hz, I almost never actually clear 150fps. So a 3070/2080 tier card would allow for AAA games to run at Max settings and hit solid FPS targets. My 1080 is paired with a 4.6 ghz 6700k for reference.
https://linustechtips.com/topic/1236008-pc-build-help/#findComment-13936453
Still better value with AMD though. He could easily go with an R5 3600 for the short term and stick a 4xxx in later on. With Intel you would need a board with good VRM's if you wanted a better cpu later. He hasn't mentioned a monitor resolution though, so that would need to be determined first.
https://linustechtips.com/topic/1236008-pc-build-help/#findComment-13937840
this should work just fine.
reason why i went with this 2080 super model is because it's the cheapest even though it's the x trio surprisingly.
would go with a 10600k in this case, but sadly couldn't fit the same gpu with this budget, and in this case this will perform better than a 10600k with a worse gpu (obviously).
though i would highly recommend to wait for zen 3 and ampere and big navi. and that's what i would do.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1236008-pc-build-help/#findComment-13937883
