Nvidia GeForce drivers 452.06 problem
Go to solution Solved by starry,
5 minutes ago, Zelenia said:
Hey,
I just did install latest drivers for my RTX 2060 last night and this morning I did notice that my GPU is now going to max clock speed in any game. Games that previously were running around 750Mhz now will instantly go to 1840Mhz (that's the max I've allowed through MSI Afterburner) and stay there as long as there is thermal space. Before yesterday my GPU usually did adjust the clock speed depending on load instead going "all out" at once.
This means that my GPU now runs some games at 80°C in low settings when it was 58°C yesterday. :( This is so messed up.
I don't know how to start solving this. Is this caused by some setting in GeForce Experience I'm not aware of? Some software issue between drivers and MSI Afterburner? Drivers just not working properly with my GPU? Something else? My specs are in the signature.
Thanks in advance!
DDU and install the previous version of the driver that was working before, and watch the patch notes for a bug fix. If you have a restore point just use that.
Hey,
Thanks in advance!
Gaming PC
MBO: MSI B450M MORTAR MAX           CPU: AMD Ryzen 5 3600        CPU Cooler: Noctua NH-U12S
GPU: Asus GeForce RTX 3060ti TUF OC 8GB,        RAM: Kingston 16GB (2 x 8GB) HyperX Fury DDR4 3200Mhz,
Storage: Samsung SSD 980 1TB  &   WD Blue 1 TB SSD
PSU: Corsair 650W RM650x (2018)       Case: Kolink Citadel Mesh Matx     Case Fans: 3x Noctua NF-A12x25 PWM 120mm
https://linustechtips.com/topic/1235715-nvidia-geforce-drivers-45206-problem/
As with all GPU issues, my first troubleshooting recommendation is going to be ddu and reinstall drivers.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Hey,
Thanks in advance!
Daily Driver (Lenovo Y700 Laptop)
Manjaro Linux  ||||  Intel Core i7-6700HQ  ||||  16GB DDR4-2666    ||||   GeForce GTX 960m
250GB Samsung 970 Evo | 500GB Samung 840 Evo
Windows Gaming PC
Windows 10 Pro  |||   Intel Core i7-10700k  |||   32GB DDR4-3600  |||   GeForce GTX 1660 SUPER  |||   MSI z490 A-Pro  |||   EVGA Supernova G2 650w 80+ Gold
120GB SSD | 1TB WD Blue 7200RPM
Bedroom HTPC and Emulation Box
Manjaro Linux  ||||   Intel Xeon E3-1231v3  ||||   8GB DDR3-1333  |||  Radeon RX 460   |||  Asus B85M-G
120GB SSD
Living Room HTPC - Optiplex 790 SFF
Manjaro Linux  |||  Intel Core i5-2400  |||  8GB DDR3-1333  |||  Radeon HD 5450
120GB SSD
What was the recommended software for DDU? Do I need to do it in safe mode?
Okay, I'll try first to restore my Windows to previous recovery point. GeForce Experience didn't create any restore point yesterday which is weird but I'll have to go 1 week back or so. If that doesn't fix it, I'll have to DDU I guess.
Thanks for fast responses!
Gaming PC
1 minute ago, Moonzy said:
mmm... shouldnt games run at max clock speed on your GPU though?
i don't see anything wrong other than 80c, which is fine, but a tad high
I don't understand much about GPUs and how it's programmed to work but it's just bit weird that it goes 80+ Celcius in low settings. In high/ultra my GPU just throttles now. In Superposition I did notice that performance dropped a lot (from 10k points to 8k).
Gaming PC
Display Driver Uninstaller, it is a specific software and that is it's name. You can get a download from the Guru3D website. It is generally best practice to do it in safe mode.
Windows Gaming PC
120GB SSD
120GB SSD
I used last restore point about 1 week ago and that fixed the issue. Thank you for help guys!
Next time I'll create a restore point before doing any GPU drivers update. :)
Gaming PC
Good idea! Driver updates can sometimes have bugs when they are brand new, I dont generally do them unless I need a new feature from it very soon. I only do ones that are confirmed stable. Im glad your issue is fixed.
Windows Gaming PC
120GB SSD
120GB SSD
