Best cheap vpn that does not reduce internet speed too much?
DarkEnergy
Is there a good cheap VPN that doesn't reduce your internet speed too much. I currently am trying the Spotflux free vpn. So far I like it but my internet speed is cut in half. I'm not sure if buying it increase the speed much. I am near the Chicago area.
My internet speed is pretty good considering I am really only paying for 25 down and 5 up. I don't want it lowered below 20ish with a VPN preferably. Is there any cheap VPN you guys recommend?
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
I use Private Internet Access and I really like it, I went from about 30Mb/s down and 6Mb/s up from 28Mb/s down and 9Mb/s up. It's $40 a year, and completely worth it. Considering you live near Chicago, latency should be really low considering they have some servers there.
Yes, I've heard of that one. I might do some research on it.
+rep I use it as well, awesome VPN, only issue I have had is I cannot connect to twich on some locations
I feel obligated to promote Hotspot Shield as they are a sponsor of the LTT community but then again I don't have any experience using them nor do I know if they taking a significant impact on connection speeds and ping.
Worship the Lord GabeN for he is your one true god!!!!
The Lord's Prayer
I also use PIA, but on Google Fiber (1Gbps), i get around 700-800Mbps through the VPN usually.
CPU: i7 3770k @ 4.8Ghz Motherboard: Sabertooth Z77 RAM: 16GB Corsair Vengeance GPU: GTX 780 Case: Corsair 540 Air Storage: 2x Intel 520 SSD Raid 0 PSU: Corsair AX850 Display(s): 1x 27" Samsung Monitor 3x 24" Asus Monitors Cooling: Swifttech H220 Keyboard: Logitech 710+ Mouse: Logitech G500 Headphones: Sennheiser HD 558 --- Internet: http://linustechtips.com/main/uploads/gallery/album_1107/gallery_12431_1107_23677.png My Setup:  http://linustechtips.com/main/gallery/image/7922-1-rkcf7io/ -- NAS: 3x WD Red 3TB Drives (RAIDZ-1), 5x 750gb Seagate ES HDD(RAIDZ-1), 120gb SSD for caching, OS: FreeNAS --  Server 1: Xeon E3 1275v2, 32GB of RAM, OS: ESXi 5.5 -- Server 2: Xeon E3 1220v2, 32GB of RAM, OS: ESXi 5.5
