1 minute ago, Noob872 said:
Does anyone have a recommended fan curve for me I have a gtx 1650 super msi aero itx overclocked 140 /600 and I wanted to cool the card efficiently without making too much noise as my curve right now sounds like a jet engine. I can provide more if needed
This is something that is very very custom to your case, room, ambient temp, other parts making heat in the system etc.
We can't just give you a "here use this" and it will be exactly what you want. Just play around with it until you get it to be more of what your looking for.
https://linustechtips.com/topic/1235654-fan-curve/#findComment-13933258
Ok but what should the ideal temp be for the gpu under load
https://linustechtips.com/topic/1235654-fan-curve/#findComment-13933261
There is no "ideal temp". But the general answer will be keep it under 80c and you'r fine. Colder the better, but obviously if its too loud for you, its not worth annoying yourself needlessly to keep your GPU a few C cooler. 80c and under and you'r fine.
https://linustechtips.com/topic/1235654-fan-curve/#findComment-13933267
Ok thanks have a good day
https://linustechtips.com/topic/1235654-fan-curve/#findComment-13933269
