So i was browsing the internet and my pc suddenly freezed, then after 5s continued to work well. After that i opened few tabs and boom freezed i had to shut it down. This was weird cus it didn't happen before my pc is 1.5y old. My HDD is pretty old (from my old pc) but i think that isn't the problem i mean it's showing in boot devices?? I turned on my pc and got unfixable error.
Reboot and Select proper Boot device or .... and press a key
*Windows 10 installed on my SSD.
*I have gigabyte mobo and SSD.
•i tried : cleaning ram, added new CMOS battery, removing and putting back sata cables on both ssd and hdd, satafirm s11 is placed as first boot device( why do i have invisible row ?? )
https://linustechtips.com/topic/1235261-help-problem-with-booting/
Had the same issue, for me it was the June 10th windows update. I couldn't recover any files as the partition table was damaged and the drive locked up somehow. Reformatting, reinstalling windows and then blocking the update did the trick, or delay windows updates by 30 days, there is an option in windows update settings that you can hit a couple of times.
I now it was the update because I had it on several computers from Core 2 Duo, AMD FX to Ryzen systems more than once.
Your SSD died, Your SSD firmware got messed up, you should flash a new firmware, format and reinstall windows form stratch
