welcome to the forums!
please fill in the form, it was made for a reason :D
Quote
Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13928703
your pcpp didnt embed for some reason but here's what i'd change:
motherboard can be downgraded to a cheaper b450 with onboard wifi if you don't think you'll need the b550 featureset. depending on the games you play and the resolution you use you can drop the 3600 for a 3100 and get a 1660 super instead of the 1650 super. case is flexible, if you prefer the look of another cheaper case then go ahead and get it, airflow doesnt really matter for this low-power of a build. spending 100 bucks on a windows license is kind of a waste, if you're still a student you can get a free educational license which is identical to home, or get a grey market key off of ebay for 5 bucks
topics i need help on:
my "oops i bought intel right before zen 3 releases" build
CPU: Ryzen 5 3600 (placeholder)
GPU: Gigabyte 980ti Xtreme (also placeholder), deshroud w/ generic 1200rpm 120mm fans x2, stock bios 130% power, no voltage offset: +70 core +400 mem
Memory: 2x16gb GSkill Trident Z RGB 3600C16, 14-15-30-288@1.45v
Motherboard: Asus ROG Strix X570-E Gaming
Cooler: Noctua NH-D15S w/ white chromax bling
OS Drive: Samsung PM981 1tb (OEM 970 Evo)
Storage Drive: XPG SX8200 Pro 2tb
Backup Storage: Seagate Barracuda Compute 4TB
PSU: Seasonic Prime Ultra Titanium 750W w/ black/white Cablemod extensions
Case: Fractal Design Meshify C Dark (to be replaced with a good case shortly)
basically everything was bought used off of reddit or here, only new component was the case. absolutely nutty deals for some of these parts, ill have to tally it all up once it's "done" :D
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13928723
Budget (including currency): $800 (currently have $100+)
Country: USA
Games, programs or workloads that it will be used for: Gaming and Editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Good FPS (lowest:60-70), 1080P quality, wireless adapter
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13929468
Country: USA
good alternatives to the b550-a that i suggested, if you wanna save a few bucks:
https://pcpartpicker.com/product/43BTwP/gigabyte-b450-aorus-pro-wifi-rev-10-atx-am4-motherboard-b450-aorus-pro-wifi-rev-10 has onboard wifi 5 and 2x m.2 slots
https://pcpartpicker.com/product/BHBhP6/msi-b450-gaming-plus-max-atx-am4-motherboard-b450-gaming-plus-max or https://pcpartpicker.com/product/XJbCmG/msi-b450-a-pro-max-atx-am4-motherboard-b450-a-pro-max a b450 tomahawk but at the right price point, good vrms and memory support. both are the same aside from display outputs if you use an APU.
also, western digital had their sn550 500gb on sale for 53 bucks last night, that'd be a good cheaper alternative to the sx8200 pro
15 minutes ago, YT_DomDaBomb20 said:
a 2060 is probably overkill for a 1080p build eh? and would a usb wifi adapter be as good as a pcie one?
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13929552
A 2060 was made for 1080p, to save cash you can always downgrade, it really isn’t a big deal, I promise, if you aren’t streaming 8k to 16 sources you won’t notice the difference
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13929662
eh fair enough, i figure a 1650S/1660S would be more than enough though considering theyre effectively a 1060/1070 which hold up well these days
https://linustechtips.com/topic/1235168-first-pc-build/#findComment-13929666
